Happilyretired
Oct 29, 2021Tutor
Confused about change in WPS LED behavior
I actually have a model EX6100v2 but that model is not listed in the drop down menu. I've had the latest firmware installed (ver. V1.0.1.106 for awhile. I've enjoyed nominal behavior for several ye...
- Oct 29, 2021
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Oct 29, 2021Guru - Experienced User
Thank you.
Happilyretired
Oct 29, 2021Tutor
Thanks about the information and link. I've posted my msg there.
- FURRYe38Oct 29, 2021Guru - Experienced User
- HappilyretiredOct 29, 2021Tutor
I posted it on the forum page you suggested. So far, no replies there. If you meant to include some info in your most recent reply above (2:17 PM today),, there was none.
