Bethm514
Oct 22, 2022Aspirant
Conncection problems-AC1750 model. Cant figure out how to change connection
Hi, I keep having devices disconnect and have to reboot my router daily. On the nighthawk app I ran a wifi analytics and its running it thru a router in my basement. How can I change that to my main ...
Oct 22, 2022Guru - Experienced User
What actual setup do you have?
You have 2x routers?
What routers are these? (hint, ac1750 is a speed, not a model)
Are they mesh devices?
Are you using separate ssid's for them or did you name them the same?
What modem/gateway are they connected to?
Details are key, you really didn't give us much to go off and a fairly vague description of your problem
