Vishalsaxena
Feb 01, 2018Aspirant
Connecivity Issues
Phone or iPad disconnects automatically from 2.5 MHz frequency and does not reconnect again even after putting the password. How to resolve this issue.
- Feb 13, 2018
Hi Vishalsaxena,
1. Here are the steps on how to change the channel.
http://kb.netgear.com/app/answers/detail/a_id/1027
http://kb.netgear.com/app/answers/detail/a_id/24095
2. If the issue persists, you can check the link below for the steps on how to reset the router to factory settings.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
DexterJB
Feb 11, 2018NETGEAR Moderator
Hi Vishalsaxena,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Vishalsaxena
Feb 11, 2018Aspirant
Hi Dexter,
sorry for late reply but the problem is not yet resolved
To answer your questions
1. The firmware version of my router is V 1.1.0.64
2. All the devices which were connected initially with 2.4 GHz frequency are not able to connect to the same. The 2 frequencies have been named separately.
The name of 2.4 GHz frequency was changed but it is kept same for 5 MHz as provided.
On the genie app it shows both the frequencies have same number of devices connected. (Screenshots attached)
3. The issue is only with 2.4 GHz band. It shows in the WiFi available but is unable to connect even after entering the password again & again.
4. For resting the router , I just switched it off and restarted again but no success.
5. How to proceed with changing the channel? Kindly guide.
Thanks a lot.
Trying to attach the screen shot of both the frequency connections but it seems that only photo can be uploaded.
Will send another photo later .
