Amitami
Feb 09, 2021Aspirant
Connect 2 RBK752 systems
Hi, I have already a AX4200 router wired to the modem with a satellite. Can I add a second AX4200 router and satellite to the same mesh network? The second router should in best case not be wir...
slthomas
Apr 02, 2021Aspirant
Did you get this figured out? I'm trying to do the exact same thing and can't figure it out. I thought i could purchase 2 RBK752 sets and link them into one mesh network.
Thanks,
Stephen
- AmitamiApr 03, 2021Aspirant
Hi, unfortunately you can't connect 2 routers in the same mesh network as the router cannot act as a satellite. However, you can built a second network wired only with the router.
