cgl48
Apr 07, 2018Aspirant
Connected AC1200 to ATT fiber gateway, 300megs, cannot put out more that 70megs on 5g
Connected via ethernet R6120 to ATT fiber gateway, 300 megs, max output is 70 megs does anyone know solution to get 300 megs out of R6120???
- Apr 08, 2018
If you are looking at the R6XXX range, pretty well anything apart from the R6120.
R6050, R6200, R6220 and so on.
Look for something that supports 1000BASE-T on the LAN and WAN.
As I said, now that internet speeds are often 100 Mbps or more, I am surprised that Netgear still sells stuff that is stuck at 100BASE-T.
cgl48
Apr 08, 2018Aspirant
Thanks michaelkenward, what do you recommend then? I'll return this one.
Thanks again
michaelkenward
Apr 08, 2018Guru - Experienced User
- cgl48Apr 08, 2018Aspirant
Thank you for your guidance!!!
