GamRHero95
Oct 10, 2021Follower
Connected No Internet After Reset
I need serious help. After I reset my router and finding the password when trying to connect wirelessly, it went through but it said "Connected, No Internet". Mind you I had my Netgear C3700 router...
Oct 11, 2021Guru - Experienced User
I couldn't tell by the photos if the lights where actually "on" other than the 2.4ghz/5ghz being lit up green. Not sure if its my crappy monitor or just to much light in the photo. Are the power/upstream/downstream/internet icons on and what color are they?
Do you have a screen snip of the cable connections page and event logs?
Try going to 192.168.100.1 for an address for it.
