Brucebo
Sep 29, 2016Tutor
Connected USB drive listed as "Not Shared". How do I share it?
Model # AC1450 I turned off sharing due to no password protection. Now I can't figure out how to share it again. Nothing in the Readshare web app seems to enable it. The "Edit" button on the ...
- Sep 29, 2016
I appear to have found the problem. The Google Chrome browser wasn't allowing the "Edit" popup to appear and I was none the wiser. I tried a different browser (Pale Moon) and when I clicked the "Edit" button a new window appeared allowing me to add another share.
Brucebo
Sep 29, 2016Tutor
ElaineM
Sep 30, 2016NETGEAR Employee Retired
Thank you for the update.
Is everything working now?
- BruceboSep 30, 2016Tutor
Yes. Everything is working fine now. This isn't the first time I've had invisible popup issues with Google Chrome. Couldn't flight check-in to British Airways once in Chrome because relevant popups wouldn't appear.
Thanks,
-B
