Brucebo
Sep 29, 2016Tutor
Connected USB drive listed as "Not Shared". How do I share it?
Model # AC1450 I turned off sharing due to no password protection. Now I can't figure out how to share it again. Nothing in the Readshare web app seems to enable it. The "Edit" button on the ...
- Sep 29, 2016
I appear to have found the problem. The Google Chrome browser wasn't allowing the "Edit" popup to appear and I was none the wiser. I tried a different browser (Pale Moon) and when I clicked the "Edit" button a new window appeared allowing me to add another share.
ElaineM
Sep 30, 2016NETGEAR Employee Retired
Thank you for the update.
Is everything working now?
Brucebo
Sep 30, 2016Tutor
Yes. Everything is working fine now. This isn't the first time I've had invisible popup issues with Google Chrome. Couldn't flight check-in to British Airways once in Chrome because relevant popups wouldn't appear.
Thanks,
-B
