nelgnej
Mar 21, 2018Tutor
connecting a D7800 to Huawei HG659.
I recently had the NBN connected and was supplied a Huawei HG659 modem/router by the telco. I need to use this HG659 modem/router because of the voip connection. I want to connect my D7800 so I can u...
antinode
Mar 21, 2018Guru
> [...] I want to connect my D7800 so I can use the features of the
> D7800. [...]
Which "the features of the D7800"?
> I have set the HG659 AS 198.168.1.1 and the D7800 as 198.168.1.2.
Normally, the D7800 doesn't have one address, it has a LAN address
and a WAN/Internet address.
> But can't get a connection to the D7800 at 198.168.1.2.
Starting from where? Doing what?
Cascading multiple routers can cause multiple problems. If you can't
configure the HG659 as a modem (only), then I'd suggest configuring the
D7800 as a wireless access point (ADVANCED > Advanced Setup > Router / AP
Mode). This will disable some router features, but you may not care:
https://kb.netgear.com/26765/
If you don't already have the appropriate user manual, then visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual. Look for "Set Up the Modem Router
as a WiFi Access Point Only".
> [...] go to Basic-Intetnet -Router Macaddress- Select "Use this
> computer Macaddress" Apply.
I don't think so.
- nelgnejMar 22, 2018Tutor
DHCP and wireless. I want to use the HG659 as a modem (only) and D7800 to do the rest.
Starting from where? Doing what?I have the D7800 connected to a switch as well the main PC. connections I am trying in Firefox are - 192.168.1.2 and http://www.routerlogin.net and both fail
