NETO84
May 15, 2022Aspirant
Connecting a N300 WNR2000 v5 router to Starlink ethernet adapter
I connected my older N300 WNR2000 v5 router to a Starlink ethernet adapter. I was successful in getting internet using the Netgear Genie interface; however, I do not get near the internet speed comp...
- May 19, 2022
as it was stated by the previous post the wnr2000 will not come close to giving you top speeds, that is an old router. I think its time to upgrade to something more newer and powerful.
May 16, 2022Guru - Experienced User
1. the startlink router is much more capable than the wnr2000. the WNR2000 doesn't even have gigabit ports. Only 10/100mbps ports.
2. the wnr2000 is a n300 device. 20 mbps over wireless might be around where you sit for speed over 2.4ghz because its a slow network and sensitive to interference. I think the max I ever got out of it was 40mbps when I had one. but if you're in an area with crowded wifi, 2.4ghz is going to be next to useless.
3. the starlink router has its own router capabilities. Connecting another router to it causes a double nat unless setup right.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
