Adhamkhorshed
Mar 16, 2018Aspirant
Connecting an N600 router to an adsl modem
How to connect an N600 router to an adsl modem ?
- Mar 17, 2018
Sorry by the way my modem router is a TP LINk TD-W8961ND 300mbps Wireless N ADSL2
It is not secret or something i just didn't want to mention any different product than Netgear :)
antinode
Mar 16, 2018Guru
Ethernet cable?
"N600" is a speed, not a model number. Ever helpful, Netgear product
packaging emphasizes speeds like "Nxxx", but that's not the model
identifier. Look at the product label.
"an adsl modem" is not a very detailed description of anything,
either.
Is this a new installation, or are you adding equipment to an
existing installation, or what? What, exactly, are you trying to do?
In any case you may need to supply some actual information before you'll
get much specific advice.
For a Netgear device, visit http://netgear.com/support , put in your
model number, and look for Documentation. Get the User Manual. Read.
