Adhamkhorshed
Mar 16, 2018Aspirant
Connecting an N600 router to an adsl modem
How to connect an N600 router to an adsl modem ?
- Mar 17, 2018
Sorry by the way my modem router is a TP LINk TD-W8961ND 300mbps Wireless N ADSL2
It is not secret or something i just didn't want to mention any different product than Netgear :)
michaelkenward
Mar 17, 2018Guru - Experienced User
Which modem? Is it one that also doubles as a router?
Adhamkhorshed
Mar 17, 2018Aspirant
My router model is WNDR3400 and I want to connect it to an already working adsl modem router
- michaelkenwardMar 17, 2018Guru - Experienced User
Yes, but what is the modem? Does it have LAN sockets on the back? Does it do wifi?
There is support stuff and a manual for the WNDR3400 somewhere at the end of this link:
>>> WNDR3400v1 | Product | Support | NETGEAR <<<
- AdhamkhorshedMar 17, 2018AspirantYes it got a wan and 4 lan sockets it is already working but I want to replace it with my new Netgear router
- antinodeMar 17, 2018Guru
https://community.netgear.com/t5/x/x/m-p/1528575
Plz how can I connect a Netgear N600 dual band router Model
WNDR3400 to an exciting working wireless adsl modem router,or can
I plug into it the isp asdsl cable directly?
> Yes it got a wan and 4 lan sockets [...]
So, a modem+router, not a modem. Does it have a maker and model
number, or are these secrets? How difficult are you trying to make
this?
> [...] it is already working but I want to replace it with my new
> Netgear router
Why? Is there some actual problem which you are trying to solve?
The WNDR3400 is a router, not a modem+router, so, no, you can't
connect it directly to a DSL telephone line. (Does it have a telephone
cable connector like the one on your (unspecified) modem+router?)
It might be possible to configure your (unspecified) modem+router as
a modem-only, which you could use with the WNDR3400 as a router, but
with no real information about your (unspecified) modem+router, or how
it's configured, it's not certain.
It should also be possible to use the WNDR3400 as a wireless access
point with your (unspecified) modem+router. One set of instructions on
how to do this should be here:
https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a C6300, but the steps are about the same for any
other router (any make/model) which lacks a one-step WAP option,
including a WNDR3400. Note that in this mode, you do not use the
WAN/Internet port on the WNDR3400.
Knowing nothing about what you want to do makes it hard to offer
specific advice.
