Mike23
Sep 18, 2017Aspirant
Connecting CG3000 cable modem with R6220
Hello I have a Netgear CG3000 cable modem hard erthernet cable connected with a Netgear R6220 to extend the range. It works but the R6220 has been setup with a different SSID so there is no roam...
- Sep 18, 2017Yes, change it to be the same. Make sure the R6220 and CG3000 have some distances separating them. You don't want to sitting too close together.
It would be best to use WPA2-PSK [AES] exclusively. It's the most secure option.
TheEther
Sep 18, 2017Guru
The R6220 is a router, not a modem.
Set it up with the same SSID and Wi-Fi password.
You should only have one device operating as a router. The CG3000 has a built-in router, so you should convert the R6220 into an Access Point. This is done by enabling AP mode under ADVANCED > Advanced Setup > Wireless AP.
Mike23
Thank you for this reply
I understand from your message that I should login to the R6220 (slave) and set it to be an access point per your instructions.
Should I also change the SSID on the R6220 to be the same as the SSID on the CG3000 router?
Also, I note that the encryption is not set the same on the two devices
CG3000 - WPA-PSK [TKIP] + WPA2-PSK [AES]
R6220 - WPA2-PSK [AES]
does this matter?
- TheEtherSep 18, 2017GuruYes, change it to be the same. Make sure the R6220 and CG3000 have some distances separating them. You don't want to sitting too close together.
It would be best to use WPA2-PSK [AES] exclusively. It's the most secure option.- Mike23Sep 18, 2017Aspirant
Many thakks - it all works.
