sailorgirl's avatar
sailorgirl
Connecting to Windstream fiber internet with PPPoE
Tried several times to connect to Windstream fiber network without success.  Windstream says I don't need a modem to connect.  They use PPPoE protocol with their system.  I have asked 3 times for the...
  • sailorgirl's avatar
    May 14, 2019
    Finally resolved the issue.  For those with Windstream ISP high speed fiber coming into their home, the ORBI RBK20 will work.  No modem is required.  Attach the ethernet cable coming out of the wall to the internet port of the router.  Then proceed through the orbi app commands.  When the app tries to connect to the internet it fails.  Go to advance settings and chose PPPOE as the protocol.  This will prompt you for a username and password.  This information was provided to me after multiple calls to Windstream's technical service.  The user name needed is the email address provided by Windstream to you at installation.  In my case, I never got it.  It will typically be in the format of [email protected].  The windstream people can tell you your assigned email and the password associated with that email address.  Inputting that into the orbi app resulted in the router linking to the windstream internet signal.  My wifi speed doubled instantly to the speed I had hoped to receive from Windstream, but never got through their rental router.  I hope this helps those Windstream customers out there trying to install a better router.
