Jackaloopt's avatar
Sep 08, 2018
Connecting Two GS116Ev2 Switches Best Practices
I have two GS116Ev2 switches connected together with one CAT6 ethernet cable between the two.  One of the switches which is located in the office upstairs and connected to the R7000 router and the ot...
  • Jackaloopt's avatar
    Jackaloopt
    Sep 11, 2018
    Hello,
    After some trial and error, I found that the Ethernet cable to the AppleTV 4K was at fault and everything is working again.
    To answer your questions:
    The Cable Modem, router, first switch and video server are all located on the second floor office and connected by their respective Ethernet ports.
    The second switch and AppleTV are located in the Den on the first floor.
    The connection is Router>Switch>Switch>AppleTV.
