bryan441
May 11, 2020Star
Connection limit on laptop but mobile device connection ok
Hello everyone!! I hope you are fine. I have a critical problem my wifi connection showing limit on my windows 8, hp laptop but at the same time i can browse with mobile device. And unable to browse...
- May 12, 2020
1. What modem are you using?
2. Is that really your router? the WNR612v2 you put in the bottom?
3. have you tried resetting and reinstall the WNR612v2? or even re-installing the firmware to the router? maybe it isn't a device issue. And that device is 10 years old. maybe the firmware was corrupted at some point.
it might also be time for an upgrade. The WNR612v2 was made in 2010 and was below base model when it came out. Its a single band n150 device with only 2x 10/100mbps ports. Unless you're on pretty slow dsl or dialup, an upgrade wouldn't be a bad idea.
May 12, 2020Guru - Experienced User
bryan441
May 13, 2020Star
1. Model no. shows WNR612.
2. Yes it is.
3. I did not reset the router because not only could I browse with my laptop but I could also browse with my mobile device.
By the way, I have setup my laptop, it is no longer a problem.
And thanks for your suggestion.
