alani
Nov 17, 2020Aspirant
connection problem
I cannot establise internet connection Power LED and WiFi Led are soild green .Internet light is off
Nov 17, 2020Guru - Experienced User
What modem/gateway are you using?
The WAC124 is by default an Access point and comes in access point mode. meaning it doesn't have a dhcp server running. You can switch it so it'll function as a router but it needs to be done through the settings. Page 23 and 163 are beneficial to changing modes on this.
Find the manual here:
https://www.netgear.com/support/product/WAC124
