alani
Nov 17, 2020Aspirant
connection problem
I cannot establise internet connection Power LED and WiFi Led are soild green .Internet light is off
alani
Nov 18, 2020Aspirant
Thank you for your prompt response, I appreciate your help in advance. my device is Fiber Modum and router together but does not cover all rooms so I need to have a separate router to enhance my network the problem is the internet connection is not established as follows
1. when I switch the power is on the Power LED lights solid green
2. The WiFi LED lights solid green
3. The internet LED Does not switch on and it means the internet connection is not established
- plemansNov 18, 2020Guru - Experienced User
