CorvusLutra
Jan 13, 2021Tutor
Connection problems and "WLAN access rejected: incorrect security" in logs
Hi - I'm having a lot of problems with an RAX20 (which isn't an option in the "Model" field, for some reason, so I chose the closest match) in Access Point mode. I'm seeing numerous log entries showi...
Jan 13, 2021Guru - Experienced User
A couple things.
1. You might get more help in the proper forum. You're in the general forum when you have an AX router.
2. when you post in the proper forum include what modem/gateway you have
3. And what firmware is on the router
CorvusLutra
Jan 13, 2021Tutor
Thanks.
