DazParks
Jul 26, 2020Aspirant
Connection speed in router not increased after upgrading AT+T Internet
Hi I had a 300Mb AT+T Internet service and the Connection speed (in Nighthawk app) showed about 300Mb. I recently increased the AT+T Internet speed from 300Mb to 1Gb, but the Connection speed in...
- Aug 21, 2020
I recieved a new router and the problem still remains. I think this is a Netgear issue as so many other issues posted that are similar ti mine without a proven solution. Therefore, if your reading this and have a internet connection >300Mb, i would suggest not getting a Netgear product.
Jul 27, 2020Guru - Experienced User
You're using the built in speedtest app?
I'd avoid that. It rarely picks the best server.
download the app/program or use an online browser based test and test hardwired.
DazParks
Jul 27, 2020Aspirant
Hi
Thanks again for your responce.
I understand that the Ookla speedtest built into the Nighthawk app will not be the most reliable way to speedtest, but it should be good enough to get a rough idea of the speed between R7000 and modem. Right now its showing about 300Mb but should be closer to 1Gb.
I have read many issues similar to mine, none of which has a tried and tested resolution, some people seem to have got lucky, others havent, I guess im one of the ones who will not get lucky but at least the R7000 will make a good but expensive paper weight.
- DazParksJul 27, 2020Aspirant
Final Update - I paid $50 for a single support instance. Spent about an hour doing similar tests to the ones suggested above. The issue remains so I will be getting a new R7000 and refunded the $50. I will be out of pocket about $17 that I will need to pay for the return of the existing R7000 once I recieve the new R7000.
- DazParksAug 21, 2020Aspirant
