Anonymous
Feb 11, 2017Constant amber power light on R6400 router
My Netgear R6400 router is not powering on correctly. I use it for both LAN and WiFi connectivity. It is not allowing internet access via either method. Both the Power and Internet led lights a...
- Apr 25, 2017
Hi velvetwood,
1. Are you referring to the Internet light (planet symbol)?
2. Please make sure that you are able to go online straight from the modem (ISP's device).
3. You can try MAC spoofing. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
VE6CGX
Feb 11, 2017Master
It is either your AC adapter is heading South or as a result the firmware is corrupt. Just make sure
the adaopter is good B4 you do anything. If adaptor checks out try tftp to reload f/w.
Anonymous
Feb 11, 2017Hi VE6CGX:
Thank you for the info. I just checked the output voltage of the adaptor and it is 15 volts. The adaptor is labeled as having a 12 volt output. Perhaps this over voltage is enough to cause a problem. I am going to seek out another 12 volt adaptor and see if that might work.
Thanks again,
Shawn
- AnonymousFeb 12, 2017
Update to R6400 Router problem.
I picked up another Netgear 12 VDC output adaptor and tried that with my router with no resolution. The second power adaptor also had a 15+VDC output.
- VE6CGXFeb 12, 2017Master
Just measuring voltage output is not meanful. You have to test it under load. I have a little jig I can put in series with adapter output cable
which enables me to measure the voltage and current when plugged in and router powered up.. Also using a O'scope I can see how clean the out put current is. Some times theybecomes intermittent; like good for a while bad for a while >>> until it quits. Amber LED means CFE boot loader time which means it is waiting for a f/w. Like I mention earlier if you can ping the router, there is good chance tftp will work for you. Good luck.
- steakhouseFeb 15, 2017Tutor
Sorry for hijacking this thread but I have a very similar problem with my 6 months old R6400 router.
I rebooted it the other days because it had performance issues with the 2.4GHz WIFI network and I thought that should be the first try. After that it couldn't connect to the Netgear CM500 modem anymore and didn't get an IPv4 address. The power LED and the internet LED stay amber. Though I can still access the UI of the router. The WIFI still works but the router doesn't get an IP address from the Netgear CM500 modem (even when spoofing MAC addresses). Interestingly when enabling IPv6 it at least gets an IPv6 address but this doesn't allow proper surfing on the web.
I tried everything recommended, like powercycling, factory reset, firmware upgrade to latest firmware, disconntected over night, etc.
It's definitely the router as I bought a replacement router (same model) as I need internet and it worked like a charm (everything turned white after a few minutes).
So I'm also curios if there is anything that can be done, like uploading a recovery OS image or something like that. Can't believe the router stops working properly after a power-off and a restart. :(
Thanks!
