Retired_Member
Feb 11, 2017Constant amber power light on R6400 router
My Netgear R6400 router is not powering on correctly. I use it for both LAN and WiFi connectivity. It is not allowing internet access via either method. Both the Power and Internet led lights a...
- Apr 25, 2017
Hi velvetwood,
1. Are you referring to the Internet light (planet symbol)?
2. Please make sure that you are able to go online straight from the modem (ISP's device).
3. You can try MAC spoofing. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
stew6283
Mar 14, 2017Tutor
Called. Outside of warranty period, wanted to charge me $130 to renew support with no guarantee of fixing the router. R6400 brand new is around that cost. I was told to make sure that I never turn on automatic updates on the router and that I should never install firmware upgrades. Really? Pretty disappointed in support. Maybe we could build a house with all of our Netgear bricks.
Thanks for your reply crickiz.
- DexterJBMar 15, 2017NETGEAR Moderator
Hi stew6283,
You can try TFTP. You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/22688
Dexter
Community Team
- productionhelpMay 31, 2017Aspirant
Too many problems too soon with my R6400 router. Purchased it at Best Buy at the end of January 2017 and it's worthless to me now. Unfortunately, I'm past the 90-day customer support so Netgear wants to extort another $90 from me to correct the problems I'm having with this flawed product. After reading many posts, it appears there are several issues with the firmware updates and various other problems. It's a shame that Netgear doesn't care enough about their customers to offer extended support at no additional charge. Super Sad face emoji from this customer. Shame on you Netgear!
