Retired_Member
Feb 11, 2017Constant amber power light on R6400 router
My Netgear R6400 router is not powering on correctly. I use it for both LAN and WiFi connectivity. It is not allowing internet access via either method. Both the Power and Internet led lights a...
- Apr 25, 2017
Hi velvetwood,
1. Are you referring to the Internet light (planet symbol)?
2. Please make sure that you are able to go online straight from the modem (ISP's device).
3. You can try MAC spoofing. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
Crickiz
Mar 14, 2017Tutor
They tried to get me to pay, just to tell me suggestions on how to fix it as well. I've heard much better reviews for ASUS, and having owned one in another house ive also have had good luck with them.
I think that's where I'll put my loyalty next time :).
