Retired_Member
Feb 11, 2017Constant amber power light on R6400 router
My Netgear R6400 router is not powering on correctly. I use it for both LAN and WiFi connectivity. It is not allowing internet access via either method. Both the Power and Internet led lights a...
- Apr 25, 2017
Hi velvetwood,
1. Are you referring to the Internet light (planet symbol)?
2. Please make sure that you are able to go online straight from the modem (ISP's device).
3. You can try MAC spoofing. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
stew6283
Mar 15, 2017Tutor
Have tried static ip and tftp and command prompt tftp put, cannot ping the router, seems like zero communication between the router.
Crickiz
Mar 16, 2017Tutor
Does it not seem fishy that all of our routers were bricked within a month of each other? I bet there are many more people who arn't on this forum with the same problem.
- Retired_MemberMar 23, 2017
Dear Boys & Girls:
Thanks for all your help. After what I considered an acceptable amount of unpaid time and effort attempting to resurrect my Netgear R6400 router, I have sold it for salvage value and sent it on to a more able and / or a more patient techno-savant for possible restoration. I myself have evolved on to another brand of router that has been serving me well for these many weeks since Netgear router burpus-interuptus. It would have been fortunate if Netgear tech staff were able to have contacted me and instructed me to forward on my inactive router at my cost and with a prepaid return label, for a likely minimal-time restoration back to factory settings service….. Alas, such matters did not happen and I have now moved on to more prosperous fields…..
Fare thee well oh Netgear router-dom.
Cheers amigos !
