Retired_Member
Feb 11, 2017Constant amber power light on R6400 router
My Netgear R6400 router is not powering on correctly. I use it for both LAN and WiFi connectivity. It is not allowing internet access via either method. Both the Power and Internet led lights a...
- Apr 25, 2017
Hi velvetwood,
1. Are you referring to the Internet light (planet symbol)?
2. Please make sure that you are able to go online straight from the modem (ISP's device).
3. You can try MAC spoofing. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
DexterJB
Apr 25, 2017NETGEAR Moderator
Hi velvetwood,
Dexter
Community Team
DexterJB
May 01, 2017NETGEAR Moderator
Hi velvetwood,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
