DnetG's avatar
DnetG
Constant Connection Timeout Error N300/C3000 Cable Modem Router
I've been using the Netgear router (N300/C3000) for about 4 years and recently, about 6 months ago, its began to timeout. The error I receive on and off is below. Any suggestion on a fix? Thanks!   ...
  • plemans's avatar
    Jan 03, 2020
    usually means theres issues with your signal.
    Log into the modem part and take a screen snip of your modem upload/download connections page. This shows us signal strengths and errors to see if its an issue with the line.
    also remove any splitters, amplifiers, attenuators from your line. Prefereably move the C3000 to directly where the line enters the home so it avoids a damaged coax within the home causing the issue.
