980energy
Jul 26, 2017Aspirant
constant lag on 2g, and cant connect to 5g
I am having a bunch of connection issues. I used 5g for everything and then one day I just got disconnected from it and it made me use 2g. I was constantly lagging on 2g. When I tried to connect to 5...
DexterJB
Jul 27, 2017NETGEAR Moderator
Hi 980energy,
1. What is the firmware version of the router?
2. Have you tried changing the wireless channel for either of the 2.4GHz or 5GHz?
3. Have you tried resetting the router?
4. Does the issue persist on all your wireless devices?
Dexter
Community Team
- 980energyJul 28, 2017Aspirant
1. My firmware version is: V1.0.3.6_1.0.63CH
2. I have changed the channel on 5g and nothing seemed to change
3. I have not tried to reset the router, I will do that though
4. The issue does persist on all devices in the house
Thanks for your help
Reseting it did work. I can't believe I didn't thinik of that. Thanks for the help.
