980energy
Jul 26, 2017Aspirant
constant lag on 2g, and cant connect to 5g
I am having a bunch of connection issues. I used 5g for everything and then one day I just got disconnected from it and it made me use 2g. I was constantly lagging on 2g. When I tried to connect to 5...
980energy
Jul 28, 2017Aspirant
1. My firmware version is: V1.0.3.6_1.0.63CH
2. I have changed the channel on 5g and nothing seemed to change
3. I have not tried to reset the router, I will do that though
4. The issue does persist on all devices in the house
Thanks for your help
980energy
Reseting it did work. I can't believe I didn't thinik of that. Thanks for the help.
