lancer586
Aug 09, 2021Aspirant
Constant ping issues/lag/disconnects
Hey guys, Lately i been experiencing tons of ping, lag issues, random disconnects. I just recently switched from xfinity internet to wowway because there was a really good package deal that had f...
lancer586
For some reason its not letting me post the cable connection page.
Aug 10, 2021Guru - Experienced User
Click on "choose file" and add it one file at a time.
- lancer586Aug 10, 2021Aspirant
ok here is the cable connection.
- plemansAug 10, 2021Guru - Experienced User
You have quite a few errors in your lines. coupled with your logs it tends to indicate line issues.
check the line for damage, kinks, old/cheap/loose/corroded connections and replace them if you do.
remove any splitters, amplifiers, or signal attenuators
