dkgoodwin00
Dec 10, 2021Tutor
constant site cannot be displayed msgs
AC1750 on Win 10 - ran most recent firmware update. Since then I am constantly getting site cannot be displayed msgs. It is across Chrome, Firefox, Brave. I have to reload page 3,4,5 times and f...
Dec 10, 2021Guru - Experienced User
what actual router do you have? AC1750 is a speed
What firmware version did you install?
What modem/gateway is it connected to?
Have you tried enabling ipv6 and rebooting the router?
If you've tried that, then try downgrading the firmware a version. Some product lines have been running into dns issues on the newer firmware.
dkgoodwin00
Dec 10, 2021Tutor
Thank you for responding, I really appreciate it.
modem: arris surfboard 6190
Netgear R6400v2
current Firmware: V1.0.4.120_10.0.91
5gz and 2.4 both set up. Pushing 5gz as default
Not a strong hardware person, so have not tried ipv6 fix. Not real sure how I go about it. Looking.
Might have to roll back, I had not upgraded for a bit so though I best do it.
DKG
- dkgoodwin00Dec 10, 2021Tutor
I see IPv6 and what setting is recommended? Auto config?
- plemansDec 11, 2021Guru - Experienced UserI usually try auto-config. I haven't had it not get a connection yet on my setup :)
- dkgoodwin00Dec 14, 2021Tutor
I thank you all for your responses. Well it seems the same time I was upgrading my router, a worm or malicious script was working its way across all the AWS (Amazon web services) using website. The report I saw yesterday estimated about 80% of sites using AWS products went down.
As I was able to get into and even play videos on site that purported to have been built outside of the AWS, I can feel assured that was the case.In case you ever want to test that theory when a bunch of sites go down... visit Brighteon, Gab and FrankSpeech sites.
Thank you all again and I hope I may be able to return the favor when you have issues.DKG
