MAC24
Oct 04, 2020Aspirant
contacting someone at NetGear
I have had an issue with my router/modem since I got it. I've been on the phone with Netgear - the last time I got disconnected. I sent an immediate message to call me back. No call back and now t...
MAC24
Oct 30, 2020Aspirant
My televisions do not recognize the new modem/router (or vice versa). The only one that automatically connects is the Smart TV. I cannot manually connect with the other televisions. Now my Firesticks only work on the smart TV. This was not an issue when I was using the Xfinity modem/router.
Oct 31, 2020Guru - Experienced User
Does the C6250 work if you're hardwired into it?
What speeds do you get hardiwired in?
When you log into it through the browser, you click on the cable connection icon. that takes you to the cable connections page.
to find the logs
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
How are you attempting to setup the tv's/firesticks?
Did you rename the ssid or setup a new one?
What did you use for a security method (wpa, wpa2, etc)
what error are you getting when you try to connect them?
- MAC24Oct 31, 2020AspirantI've tried the wired connection but that doesn't work either. I have to have a wifi connection for the fire stick to work. That's the problem. I have tried to manually set up the connection with the new ssid and password. Still doesn't work. No problem with the smart tv however.
- plemansNov 02, 2020Guru - Experienced User
So the router doesn't work if hardwired into it?
It only works for a device or 2 wireless?
