antill
Feb 10, 2022Aspirant
Control center connects but fails
I have a laptop that has win 11 communicates to a Nighthawk X45 D7800, I see that it's talking to the router and printer, BTW i have the Pinter Diver installed in the laptop. The problem is it g...
antill
Feb 11, 2022Aspirant
Yes it's using ReadyPrint
michaelkenward
Feb 11, 2022Guru - Experienced User
You have installed the USB Control Center?
- antillFeb 11, 2022Aspirant
Yes
- michaelkenwardFeb 11, 2022Guru - Experienced User
Now that your image has finally appeared, it suggests that it is connected to a USB port on the PC. That has nothing to do with your router.
We can get to an endless Q&A session if you like, but so far we know next to nothing about your system and what happens when you do things. There are usually prompts and error messages when you do anything.
