Shykoth1
Jan 19, 2017Aspirant
Control the access when connected to 2.4 GHs
When I connect my laptop to 2.4 GHz wifi then the setup wizard is not open. But when I connect to 5 GHz the it works well. Can any one tell me what is the problem on 2.4 GHz? And what is the solution?...
- Jan 30, 2017
Hi Shykoth1,
Thank you for the update.
If it is an option, you can try resetting the router then reconfigure it afterwards. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/9665
http://kb.netgear.com/app/answers/detail/a_id/22697
http://kb.netgear.com/app/answers/detail/a_id/22717
Dexter
Community Team
DexterJB
Jan 25, 2017NETGEAR Moderator
Hi Shykoth1,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Shykoth1
Jan 28, 2017Aspirant
Hello Sir!
I am so sorry for the delay. Just having some personal issues.
So you asked for these info-
1. Model-R6220 ,Router Firmware Version-V1.1.0.34_1.0.1
2. My router is configured by our internet service provider.
3. If my other device is connected with 2.4 Ghz then I also can't access the router configuration page.
Thanks for the help
- DexterJBJan 30, 2017NETGEAR Moderator
Hi Shykoth1,
Dexter
Community Team
