vonkiet's avatar
vonkiet
Convert or adapter from Coax connector to CAT5e Connector
Convert or adapter from Coax connector to CAT5e Connector Hi there! I have Wifi cable modem model C7000. My Internet Carrier use CAT5e connector but my Netgear modem C7000 has Coax connector ther...
  • antinode's avatar
    antinode
    Mar 20, 2020
    > [...] So I have to buy another router.
       Buy, rent, steal, ...
       You need a router with an Ethernet WAN/Internet port.
       Among Netgear models, Rxxxx.  (Also Dxxxx, but those are DSL
    modem+router devices, and you don't need the DSL modem section.  But
    that type of modem+router typically _does_ have an Ethernet WAN/Internet
    port, so, if you see an irresistible bargain on one, ...)
