HotRod1957's avatar
HotRod1957
Follower
Mar 08, 2021
Convert to mesh network - What do I need
I am wanting/needing to upgrade my home internet. My goal is to have one 2.4 GHz and one 5 GHz wireless mesh network. Currently, because of cable modem, router and extender, I have three 2.4 GHz wireless access points and three 5 GHz wireless access points. I need to add another extender and I don’t want to add a 4th set of access points.
Here is my current setup:
  • Cable Modem, Netgear AC1750 Model C6300
    • 4 wired ports, 3 in use
    • 2.4 GHz and 5 GHz wireless
  • Main router, Netgear Nighthawk X10 AD7200 Model R9000
    • Sits 3 feet away from the cable modem
    • 8 wired pots, 5 in use
  • Extender, Netgear EX7000, AC1900
    • Sits on other side of house
    • 4 wired ports, 2 in use
    • 2.4 GHz and 5 GHz
My goal
  • I need to add another extender to reach a dead zone.
  • I would like to move to a Mesh network so that roaming thru the house will automatically switch from one router/extender to another
  • I need to maintain the existing wired connections
  • I want to purchase the Mesh equipment without needing to replace existing equipment
Can I:
  • Turn off the wireless on the cable modem and continue to connect the cable modem to the main router (wired).
  • Turn off the wireless of the main router and connect the main router to the Mesh router (wired).
  • Add a Mesh extender and cable from the Mesh extender to my existing extender. And, turn off the wireless of the extender.
  • Will all of the above keep my existing network (the wired devices) functioning? Giving me a 2.4 GHz and 5 GHz wireless Mesh network?
  • Using one additional Mesh extender, add it in the dead zone of my house.
What do I need to purchase to make the above happen? Netgear Orbi  or Netgear Nighthawk?
No RepliesBe the first to reply
