XULACS96
Jul 18, 2016Aspirant
Copying files to external drive really slow after firm ware update.
Before I upgraded the firmware to version V1.0.0.32 files would copy to my external hard drive and 2-3 Mbytes/sec, but know it maxes out a 150kb/sec! :smileysad: I have no idea what else it could be...
- Jul 20, 2016
XULACS96 You can only revert the firmware by downloading it from the website and upload it through the admin page of the router.
It's the same instructions as the firmware upgrade but instead you upload the previous version of the firmware.
Resetting the unit does not revert the firmware back to the previous version, it just restore the router settings to its manufacture default.
ElaineM
Jul 19, 2016NETGEAR Employee Retired
Hello XULACS96
Welcome to the community!
First off, this posted has been moved under Wireless N board since you have WNDR4300v2.
For your concern, since you have upgraded the firmware I suggest that you factory reset the router.
Once done, reconfigure the router to get the internet connection back then try to copy files again.
XULACS96
Jul 20, 2016Aspirant
I tried the factory reset and it removed all my configurations but it did not revert back to the orignial firmware version. Is there some special instruction I need to follow when resetting back to factory that would also rollback the firmware?
- ElaineMJul 20, 2016NETGEAR Employee Retired
