bcousins13's avatar
bcousins13
Corrupted Firmware Update AC750 - R6020
Hello,
I've just attempted to update my firmware on my router when the update was interrupted and the firmware is now corrupted. A slow green blinking of the power button and an inability to reset this when turned off and on again.
I've looked online and tried a few different things to fix the issue.
I've downloaded the firmware update as a ZIP file and attempted to install the update via TFTP.
I am unable to do this however because when I connect to my router via an ethernet cable, it doesn't come up as though it's connected. I am unable to access the router's IP. I do not have a default gateway because the router is not registering anything.
Worse still, I thought it might save some time if I just reset the router. I attempted to do this, I found what looks to be the reset button next to the power button, I pressed this for at least a couple of minutes but this does not seem to do anything and I cannot locate any hole where the reset button might be elsewhere.
Can anyone help with this issue? Struggling to find anything on the net to resolve it.
  • are you on windows? if so, follow this guide
    https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
    just make sure you enable tftp
    https://www.thewindowsclub.com/enable-tftp-windows-10
    and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
    https://www.youtube.com/watch?v=R9DLrLQrpaw
    and if that doesn't work, you can try using nmrpflash
    https://github.com/jclehner/nmrpflash
    • bcousins13's avatar
      bcousins13
      Thanks for the reply.
      I am on windows and I followed the guide as you said and typed in the command as listed on the site (changed my file name obviously) however the response I received was that the cmd couldnt read from the local file?
      I've enabled tftp.
      I did have some success following the youtube video you posted. The program even actually said the firmware had been updated successfully, however my router still shows a flashing green power light.
      I have updated it using 2 different computers with the same result.
      I must be doing something wrong, right?
      bcousins13
      Nevermind.
      I'd read a couple of places that some firmware updates can cause the router updates to corrupt so what I did was download the earliest version of the software and work my way up until the router started working again.
      Thankfully it's working and I don't need to buy a new one.
      Thank you for your help!
