Laronski71's avatar
Laronski71
Create QOS Rules for MAC Address
I have a R6700v3  Firmware Version V1.0.4.122_10.0.95. This is a BRAND NEW ROUTER.   I'm trying to as a QOS rule for a MAC address. I go in to Advanced» QOS Setup » QoS - Priority Rules. I choose ...
  • Laronski71's avatar
    Laronski71
    Feb 09, 2022
    I didn't have any other QOS rules in place. The router simply would not accept them. I was really expecting a quick response to my question, so as I was waiting, I just decided to do a factory reset. Starting from scratch is never fun, but the factory reset was able to allow the QOS rules. AND while the router did show that I had 30+ devices connected to the router, it only listed three that was available for QOS rules; I had to enter my rule manually using a Mac address. So something is still wrong there.
    The router is functioning as I wanted to right now; that was the goal. So I consider this problem semi-resolved. Netgear still need to figure out why their device is not functioning correctly.
    I hope this helps...
