Retired_Member
Apr 21, 2023Custom Management VLAN with Insight
Has something changed? I had 2 x WAX610 on a premium insight subscription and had configured a custom management VLAN number to fit with the rest of the network - which is not Netgear. This now seems...
michaelkenward
Apr 22, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
