elysea
Oct 11, 2018Aspirant
D6000 not working following firmware upgrade
The firmware update version 1.0.0.75 did not complete and my device is no longer working. I have tried to do a factory reset but it's not responding to this. The release notes mention that an issue m...
- Oct 20, 2018
Thanks. I got a tech in from one of those mobile services that come to your home to do the recovery as I was over it, but after commenting about how many times I've had to reset the router since owning it for the last 7 months he suggested I had a lemon so I returned under warranty and got a new one of the same model. We've been all good since. Appreciate the response.
elysea
Thanks. This is my first time using a forum like this and only did because I got desperate as it appeared netgear don't provide any support unless you have their support package and I don't know what to do. The release notes simply finish with 'Please DO NOT power off or reboot the device during firmware upgrade, otherwise, it may result to a corrupt firmware and cause the device not to work.'.
I purchased the router in January 2018 so out of free 90 day support.
I performed the firmware update by - downloading the update file from the netgear website, saving to my desktop, selecting the firmware update in netgear genie, and uploading the update file. It got stuck at 71%. I left for at least half hour but it didn't move so I did a page refresh (F5). I then got an error 405 - HTTP verb used to access this page is not allowed. I then lost internet connection and wasn't able to restart the update. I tried a factory reset by pressing the reset button at the back of the router using a safety pin. The power LED light is flashing green. All other lights are green on the router.
antinode
Oct 11, 2018Guru
> [...] It got stuck at 71%. I left for at least half hour but it didn't
> move [...]
If it gets stuck for more than a few minutes, then it's probably
stuck forever.
> [...] The power LED light is flashing green. All other lights are
I'd try the TFTP recovery scheme.
