elysea
Oct 11, 2018Aspirant
D6000 not working following firmware upgrade
The firmware update version 1.0.0.75 did not complete and my device is no longer working. I have tried to do a factory reset but it's not responding to this. The release notes mention that an issue m...
- Oct 20, 2018
Thanks. I got a tech in from one of those mobile services that come to your home to do the recovery as I was over it, but after commenting about how many times I've had to reset the router since owning it for the last 7 months he suggested I had a lemon so I returned under warranty and got a new one of the same model. We've been all good since. Appreciate the response.
antinode
Oct 11, 2018Guru
> [...] It got stuck at 71%. I left for at least half hour but it didn't
> move [...]
If it gets stuck for more than a few minutes, then it's probably
stuck forever.
> [...] The power LED light is flashing green. All other lights are
> green on the router.
I'd try the TFTP recovery scheme.
elysea
Oct 20, 2018Aspirant
