Dyz
Nov 27, 2019Guide
D6100 5GHz extremely slow
Dears, I have an issue with D6100 5GHz wifi. I use Netgear for years (WNRL3500, WNDR4300, R7000, R8500). I know the software. Normally every day I use R7000 which connects with my notebook at the ...
- Dec 03, 2019
Solved!
Original software from Netgear SUCKS!
I found firmware ver. 38 and I have FULL SPEED.
Ver .52 brings the same issue as the latest one.
Dyz
Nov 27, 2019Guide
It seems, that you cannot edit your own post...
It is Cisco EPC3925
Dyz
Nov 28, 2019Guide
Anyone? Any idea?
- plemansNov 29, 2019Guru - Experienced User
sorry, holiday time and not at home.
If you go Cisco EPC3925-----D6100 in router mode, do you pull full speed?
- DyzDec 01, 2019Guide
Hi,
Yes, I am able to obtain c.a. 155 mbps via LAN.
Via 5GHz it is still the same - a slow turtle...
QoS of course is not defined. WMM is on. I checked with 'off' - the same results.
- plemansDec 01, 2019Guru - Experienced User
maybe you have a bad chip/card for the 5ghz side. If you're outside of warranty, potentially you could open it up and see if an antenna came loose.
