Dyz
Nov 27, 2019Guide
D6100 5GHz extremely slow
Dears, I have an issue with D6100 5GHz wifi. I use Netgear for years (WNRL3500, WNDR4300, R7000, R8500). I know the software. Normally every day I use R7000 which connects with my notebook at the ...
- Dec 03, 2019
Solved!
Original software from Netgear SUCKS!
I found firmware ver. 38 and I have FULL SPEED.
Ver .52 brings the same issue as the latest one.
Dyz
Dec 02, 2019Guide
Dear Plemans,
I followed your advice and disassembled thet router.
Detached and attached antennas, checked mounting (wifi card is firmly mounted with 2 screws as in notebooks). No improvements. No suspicious points visible.
Thank you very much for your will of helping me. It seems, that this toy is affected and I need to get used to it :(
Luckily, I paid c.a 7$ for that, so not a big loss, except my and your time...
Dyz
