Graham_J's avatar
Graham_J
Follower
Jul 11, 2021
D6200 Default Setting for 2.4 Mbps
Why is the default (factory) setting 150 Mbps? Shouldn't it be 300 Mbps?
  • olympos1625's avatar
    Jul 17, 2021
    Hi Graham_j,
    Good day!
    Welcome to NETGEAR Community!
    Thank you for reaching out. Up to 130 Mbps is the default and allows 802.11n and 802.11g wireless devices to join the network. g & b supports up to 54 Mbps. The 300 Mbps setting allows 802.11n devices to connect at this speed.
    https://www.downloads.netgear.com/files/GDC/D6200/D6200_UM_15Mar13.pdf page 35
    Please do not hesitate to let me know if you need further assistance.
    Oliver
    Community Team
