Garry4
May 20, 2019Aspirant
D6200 DSL statistics / connection speed
Hi all,
Sorry if this is a dumb question, I have looked online and through the manual to no avail.
All previous routers I have used allowed me to get DSL statistics, what actual rate it had train...
- May 20, 2019
> I have "Googled" it, searched the Netgear community, [...]
"it"? "Googled"/"searched" for _what_? And now I (with my weak
psychic powers) should know what you found, where?> [...] The only statistics I could find were WAN/LAN not the modem.
What do you think that "WAN" means here?
Page 93:
> To show the connection statistics:
1. Select Advanced > Administration > Router Status.
2. Click Show Statistics.
The lower section of that report ("ADSL Link [...]") refers to the
modem. (I assume that there's something similar for VDSL, but all I've
seen is ADSL.) My D7000[v1] (V1.0.1.70_1.0.1) shows a page very like
that picture in the D6200 User Manual.What, exactly, do you seek which is not shown there?
Garry4
Hi,
I have "Googled" it, searched the Netgear community, and looked through the Netgear D6200 User Manual. The only statistics I could find were WAN/LAN not the modem.
Many thanks,
Garry
antinode
May 20, 2019Guru
Page 93:
- Garry4May 21, 2019Aspirant
Hi,
Show statistics is indeed the option I needed. I had tried it earlier, but I was expecting a lot more DSL information so I blindly overlooked it.
While it isn't super informatrive, it does give me enough to talk to the line company.
Many thanks, sorry that I bothered the forum with something that was in front of me all along.
And thanks for the very prompt replies!!
- antinodeMay 21, 2019Guru
> [...] I was expecting a lot more DSL information [...]
I'm with you there. On my old Cisco 678, for example:
cbos>show interface wan0
wan0 ADSL Physical Port
Line Trained
Actual Configuration:
Overhead Framing: 3
Trellis Coding: Enabled
Standard Compliance: T1.413
Downstream Data Rate: 1536 Kbps
Upstream Data Rate: 1024 Kbps
Interleave S Downstream: 4
Interleave D Downstream: 16
Interleave R Downstream: 16
Interleave S Upstream: 4
Interleave D Upstream: 8
Interleave R Upstream: 16
Modem Microcode: G96
DSP version: 0
Operating State: Showtime/Data Mode
Configured:Echo Cancellation: Disabled
Overhead Framing: 3
Coding Gain: Auto
TX Power Attenuation: 0dB
Bit Swapping: Disabled
Remote Standard Compliance: T1.413
Tx Start Bin: 0x6
Tx End Bin: 0x1f
Data Interface: Utopia L1
Status:
Local SNR Margin: 31.5dB
Local Coding Gain: 6.5dB
Local Transmit Power: 12.3dB
Local Attenuation: 19.5dB
Remote Attenuation: 17.0dB
Local Counters:Interleaved RS Corrected Bytes: 12812247
Interleaved Symbols with CRC Errors: 13266690
No Cell Delineation Interleaved: 13628416
Out of Cell Delineation Interleaved: 14933760
Header Error Check Counter Interleaved: 13495936
Count of Severely Errored Frames: 13039872
Count of Loss of Signal Frames: 13691008
Remote Counters:
Interleaved RS Corrected Bytes: 12518235
Interleaved Symbols with CRC Errors: 15393836
No Cell Delineation Interleaved: 13267840
Header Error Check Counter Interleaved: 14120170
Count of Severely Errored Frames: 12286848
Count of Loss of Signal Frames: 12906880
Sadly, when I upgraded my (Qwest/CenturyLink) service above 1.5Mb/s,
the otherwise-satisfactory Cisco 678 couldn't keep up. It said:Downstream Data Rate: 7168 Kbps
Upstream Data Rate: 896 Kbpsbut the observed downstream speed was only about half that.
This lead to a succession of Netgear products (all of which had/have
more firmware bugs than the Cisco 678, and no supported command-line
interface).
