Internetstuff
Sep 24, 2020Aspirant
D6200 Firmware Upgrade Fail
I am attempting to manually upgrade the firmware for my D6200 modem router from 1.1.00.38 to 1.1.00.40. I am doing it manually as I do not have any internet access via this modem router. I have downl...
- Sep 27, 2020
I found the solution on another thread. Once the progress bar is full, you then reboot the modem router even though the icon above the progress bar is spinning. This step moved the installation on to the next stage. All good after that.
The upgrade to .40 allows the VLAN to be set, so I can now have NBN (Australia).
Internetstuff
I am trying to upload the .img file as per the Netgear instruction.
Internetstuff
Sep 27, 2020Aspirant
