Andorose's avatar
Andorose
Follower
May 06, 2021
D6220 - wifi not working but ethernet working
D6220 has power light and ethernet light but wifi not working.  Cannot get the router to do firmware update past V1.0.0.52.
Can't find support anywhere online for Australia for Netgear
1 Reply
  • > D6220 has power light and ethernet light but wifi not working. [...]
       Which one is "ethernet light"?  What does Netgear call it?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".  Pay particular attention to the
    "WiFi On/Off button with WiFiLED".  Did you press it?  Further reading
    might not hurt, either.
    > [...] Cannot get the router to do firmware update past V1.0.0.52.
       "Cannot" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       Regarding "Can't", see "not a useful problem description [...]",
    above.  Where did you look?  http://support.netgear.com/ ?
