hibbs
Jan 20, 2019Aspirant
D6220 Cannot connect after fibre upgrade (NZ)
Model D6220/AC1200
Recently changed from VDSL to Fibre supplied by Chorus, their ONT indicates power is on, optical signal being received and the Lan1 is orange connects to Netgear modem/router. On...
- Jan 21, 2019
> [...] Yip have ISP logon details, they are displayed in Netgear's
> Genie.
Not much meat on that bone. _Where_ "in Netgear's Genie"?
> [...] Will look at the possibility of replacing the existing unit with
> a router only, as suggested. [...]
You may need only a router, but a D6220 should be able to act as only
a router. If your problem is not configuring your D6220 properly as a
router, then you might have similar problems configuring any other
router as a router, too.
Does your ISP provide any instructions on how to attach/configure a
router to work with their ONT interface? Do you have any reason to
believe that "ISP logon details" are needed with this (non-DSL?)
connection? Have you done a settings reset on the D6220, and let it try
to puzzle out its new environment?
hibbs
Jan 21, 2019Aspirant
Yip have ISP logon details, they are displayed in Netgear's Genie. Will look at the possibility of replacing the existing unit with a router only, as suggested. Thanx again Hbbs
antinode
Jan 21, 2019Guru
> Genie.
