mikeo21's avatar
mikeo21
D6220 need voip setup
We installed the netgear D6220 modem router but now we need advice on how to set up connection with voip phone.
Its our only phone in the house so we need to fix the modem router for us to use our home phone.
What steps do we need to take please?
thanks for any help.
Mike and Lynda
  • > [...] we need advice on how to set up connection with voip phone.
       Some of your audience knows nothing about your (unspecified) "voip
    phone".
       Follow the instructions for your (unspecified) "voip phone"?
    • mikeo21's avatar
      mikeo21
      we have a vtech model 15250 phone which worked as a voip phone with an earlier modem but is not now connected to the netgear router
      • antinode's avatar
        antinode
        Guru
        > we have a vtech model 15250 phone [...]
           Swell.  And you did what with it?  Are you following some set of
        instructions?  Praying?  Decapitating chickens?
        > [...] with an earlier modem [...]
           I know nothing about that, too.
        > [...] but is not now connected to the netgear router
           "not" what?  Not working?  Not connected?
           None of that is a useful problem description.  It does not say what
        you did.  It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
