ChipsRUp
May 05, 2021Tutor
D6220 router firmware 1.0.0.72 Broken
As there is no way to contact Netgear support I thought I'd post here in the hope netgear technical support will see this. I recently upgraded the firmware on my Netgear D6220 router to the lates...
ChipsRUp
May 09, 2021Tutor
Hi. I reinstalled the lastest 1.0.0.72 firmware, did a factory reset and reinstall and the router has locked up completely twice in two days - with the latest firmware only being used for two days on latest attempt. There is definitely something wrong with 1.0.0.72 as the previous 1.0.0.68 was rock solid for a week between trying 1.0.0.72 twice.
May 09, 2021Guru - Experienced User
could simply be something unstable in it for your device then.
sounds like the downgrade is the option for you.
- ChipsRUpMay 10, 2021Tutor
Does anyone know a contact email for Netgear support or is there a Moderator on here that feeds back firmware issues to Netgear technical support? I'm not looking for support directly but I'd hope Netgear would want to know of firmware problems so they can be fixed. Shame I cannot find any contact details but that seems the way Netgear want it.
